Serendipity
   / Serendipity #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I posted a couple days ago about how I had adapted some Ford wheel weights to my Yanmar wheels. Because of the conical shape of the weights and the conical depressions in the wheels it looked like the weights would nest in the wheels with a little clearance. Because of the difference in the angles the weights would not sit against the flat face of the wheels at the bottom of the depression. So I made spacers. I measured a few times and came up with a dimension that I thought would space the weights out far enough that the weights would only contact the spacers. My dimension was off a little bit, the spacers should have been a little thicker. Except, now the weights contact the spacers and the wheel. The wheel contact is at the large diameter of the depression. I was concerned that the weights might want to shift a little as I used the tractor but with the way things turned out they fit snugly and won't tend to move and wallow out the holes in the wheels that the studs go through. Sometimes luck goes the right way.
Eric
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2018 CATERPILLAR 239D SKID STEER (A51242)
2018 CATERPILLAR...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
