septic system
   / septic system #1
loner
Bronze Member
After very careful planing for a couple of years,I screwed up!I put the old mobile home rite where I didn't want it.I can still build the new house within about 20 feet of where I wanted to without moving MH.The 64000$ question is ,how far from the septic tank can you get before you run into trouble?Is 80" of main feed line too far?The system in the new house will be very centralized with all water going the same route.It will be about 80"from farthest drain in the new house to the septic tank.The main line will be a straight shot to the tank,no elbows or turns.Am I o.k. or up you know witch creek?
   / septic system #2
Hmmm, I have a sand mound, it's 500feet from the house, and uphill about 15, with a pump... I imagine you could always add a pump to your if you got into trouble going downhill...
   / septic system
The land slops in the rite direction,downhill.500'sure seems like a very long way to me.80' should be O.K. If you have no trouble with 500'
   / septic system #4
Loner
I do not believe the distance is as important as the slope. Most codes require a 2% minimum slope. The futher away you are the higher the house has to be in relation to the tank. Determine the inlet elevation in relation to the house outlet and determine if you have a 2% slope.
Randy
   / septic system #5
My new home has an eighty-five foot run from farthest drain to the septic tank. RJohnson is right the slope is the limiting factor and that can be corrected with a pump.
My fathers old home had the septic tank and system that was two hundred feet from the house. It ran down a hill to a level area of the property.
   / septic system
Thanks alot fellas.I realy thought I had a problem.The price of a new system I was thinking I might need will be better spent on the new ,first real house.
Real good news indeed,thanks alot for the info.
loner.J.D.4200,hst
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2012 INTERNATIONAL LF687 (A53843)
2012 INTERNATIONAL...
