Dirt Moving semi mount 4 bottom plow
   / semi mount 4 bottom plow #1
kelby
mcconnelsville
ford
how much would it cost to replace worn out moldboards on a JD 4 bottom plow?
   / semi mount 4 bottom plow #2
:welcome:
jdparts would be a good place to look. Put the model number in and then find out what the parts availability is and a price.
   / semi mount 4 bottom plow #3
Try shoup parts online also.
i don't have a parts number. i can't make out the serial plate,,, but it has the john deere paint still on..
   / semi mount 4 bottom plow #5
Then you might try taking off the part and looking for a stamped no. that Deere dealer can reference.
Or get the dimensions and try Shoup parts.
   / semi mount 4 bottom plow #6
:welcome:
Plow bottom parts aren't listed in the JD plow parts catalog. Bottom parts are listed in a parts book by themselves named plow bottoms. The part numbers should be stamped on the backside of the parts if they're not worn off.
   / semi mount 4 bottom plow #7
Its impossible for anyone to say what it will cost without knowing the model/plow bottoms. If possible start searching for pictures of JD plows till you find one identical to yours. That will give you a good place to start. Then you can figure out what it will cost. Otherwise, pull off the parts and look for the part numbers on the back side. Then you can look them up.
When you do find out what plow you have or what part numbers you have make sure you write it down somewhere. I like to write the model number in permanent marker on the frame somewhere.
   / semi mount 4 bottom plow #8
But because this thread is titled semi-mount 4 bottom narrows the plow bottom part #s drastically. The points are probably throw-away type points.
think its a 145,, compared to others... frame and where cylinder hooks up
   / semi mount 4 bottom plow #10
But without a model number or at least a picture its still impossible to give an actual answer as to cost.
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
Caterpillar 259D (A50123)
Caterpillar 259D...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
