selector valve
   / selector valve #1
Vincie
I have a Kubota L3240 with one set of rear hydraulics, to operate a hydraulic shoot on a snowblower. I also have hoses running to the front loader arms from this rear valve to operate a cylinder on a snowplow. As it it plumbed now in order to switch between the snowblower chute rotator or the snowplow I must disconnect the blower hoses and reconnect the plow hoses and visa versa in order to switch between the two. I would like to install some type of valve that would let let switch between the two without fooling with the hoses. Northern tool sells a manual selector valve that looks like it would do what I want it to do. Does anyone know if that valve will work the way I want it to and if the Kubota hydraulic system will accept it or am I heade for trouble if I install it?
   / selector valve #2
What you need is a double selector valve-either manual or electric.
Electric
Manual
They will work fine with you system.
   / selector valve
That's what I hoped would be the answer. Now I must figure out how to get the valve in the area I need it. Thanks for the help.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A53472)
NEW 2022 Load...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
Kawasaki NR (A50324)
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
New Long Forks (A53002)
New Long Forks...
