Tires Selection criteria of ag or industrial tires
   / Selection criteria of ag or industrial tires #1
ArtMech
Platinum Member
Lithuania, EU
Present: 2003 Kubota M9000 DTF; 2001 Kubota B72. Sold: 1985 Kubota L2202
Fellows,
I've noticed some of You in North America select industrial tires if even a tractor is used for similar to agricultural purposes. OK, if a tractor is a second hand one, you purchase as it is. Or if a brand new tractor will be used for special projects, eg. deep ground works...
But do some of You treat industrials as an advantage against agricultural ones? Or what is a criteria of tire selection other than special purposes?
   / Selection criteria of ag or industrial tires #2
I keep it simple, Ag for Ag type stuff and Industrial for everything else. It works well for me on my types of soil. I was in the mud for the past two days and surprised how well the Industrials on my L5030 worked, but no doubt Ags would have worked better. Fortunately we had Ag's on the M8540.
   / Selection criteria of ag or industrial tires #3
Well, a lot of the guys here are very opinionated about tires, so we may open a can of worms here :) But some of the reasons to select R4 Industrial tires are: they are more puncture resistant, lower profile, wider, will take more fluid when you fill them for stability, are easier on your lawn, and there may be others. But all that said, the guys who like AG R1 tires or Turf R3 tires will have many reasons to like them as well, Better traction or even less turf damage etc. I guess R4 tires are in the middle and a compromise or do everything well type of tire. Or others would say, a compromise, do nothing well type of tire:laughing:
James K0UA
   / Selection criteria of ag or industrial tires #4
Fellows,
In my case my B3200 was then only one on the lot and it had industrial tires. I needed it quickly and didn't want to pay shipping on getting a set of ag tires in so I just took it as is. I use this tractor for some construction work, but mostly farming.
I quickly found out how terrible the industrial tires were for anything but loader work on hard surfaces, so I ended up spending big $$$ to get a set of ag tires. The tractor actually works up to it's full ability now and I am getting work done much faster with less effort than before.
I think a lot of the reason you see so many tractors in this country with industrial tires is that a) the dealers push them because generally they are the most expensive option, and b) misinformed first time buyers don't really know what their intended purpose is (construction/heavy loader work.) People think they are a combination between a turf tire and an ag tire, which they are not.
   / Selection criteria of ag or industrial tires #5
I love the looks of R4 tires the way they make the tractor sit. That said I needed traction traction and more traction so I got the R1 Ag tires and they get good traction. For me I need all the traction I can get going up the steep hills.
   / Selection criteria of ag or industrial tires #6
Very good point about the industrial tires, not being a whole lot better.They certainly are proud of them at the time of purchase.I too thought puncture resistance was the main selling point, and carrying capacity? D.
   / Selection criteria of ag or industrial tires #7
I had to think a lot about which tires to get: R1s or R4s. I went with R4s for the following reasons:
Much greater weight rating. I do a lot of FEL work and wanted/needed tires that can handle the weight. The rear tires didn't matter so much, but the fronts did. I think the front R1 ratings were like 1,300 pounds or so (each). My front R4s are like 3,500 pounds (each). If you add up the weight of the front of the tractor and the FEL, you don't have much left (if any) for material in the bucket with R1s.
Much greater puncture resistance. One of my goals I am working on is clearing several acres of locust trees. The thorns I have been driving through is amazing.
Does not tear up my front and back yards as much as R1s. (This was not a reason I weighed too heavily on, however it is a plus.)
I think that R4s look cool, however I would not base my decision on that. There are negatives going with R4s, and here they are:
Limited sizes. My R4s are shorter than I like.
Limited wheels. I would like to have cast iron wheels, but that was not an option with R4s.
Limited traction. Not NEAR as good of traction as R1s.
   / Selection criteria of ag or industrial tires #8
How puncture resistant are the industrials? I am planning on purchasing a 3720 or 4120 in the spring and it will be used mainly for bush hogging /mowing. I will also be dealing with down trees in my woods. I think the ability to drive over obstacles will be important. i am VERY careful now with my 850 which has ag tires on the back and turf on the front. It has a mmm and the original ag tires in the front created ruts while mowing. The switch to turf in the front cured the problem. The rears dont seem to harm the yard at all. It looks weird but works well.
   / Selection criteria of ag or industrial tires #9
I don't have a scientific answer on the puncture resistance between the R1s and R4s. Maybe someone else can help out?
All I know is I had several pieces of equipment (with their operators) working on my property while I was building my house. Almost every time they came out, at least one R1 tire would get a flat. The one guy with industrials never had a problem.
I have torn down (literally dug up and knocked down) about 50 locust trees and have pushed them into a burn pile. There are locust thorns stuck in my tires a lot. If you were to look at my tires, you would see hundreds of little "spots" on my tires where the thorns have stuck in and broke off. I have only had one minor leak so far... and took care of that with some green slime. I am VERY happy I went with R4s... although I do miss the traction of R1s.
R4s suck in the mud and I hear the same about snow... but they are dang tough!
   / Selection criteria of ag or industrial tires #10
Ok, thanks rjkobbeman. Sounds like the industrials are the best choice for me. I was leaning that way already. I dont get a lot of snow where I live in Ky. and I would rarely have to be out in muddy conditions.
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
JOHN DEERE 5083EN LOT NUMBER 136 (A53084)
JOHN DEERE 5083EN...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
JOHN DEERE Q820M LOT NUMBER 244 (A53084)
JOHN DEERE Q820M...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
