Seen on Craigslist
   / Seen on Craigslist #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
Axle placement? What axle placement?
Am I missing something, or is this a really unsafe trailer?
   / Seen on Craigslist #2
That is a self unloader. Very rare and not sought after. Just undo the coupler and she will fall flat on her rear end and the load will slide right out. That is if you make it home without killing yourself first pulling that death trap.
Chris
   / Seen on Craigslist #3
It looks like it was built right and some genius extended it.
   / Seen on Craigslist #4
You know, I consider my dad to be a pretty crafty guy, but when he welded up his firewood trailer, it had the axle about 4" ahead of the center of the trailer. A few years back, I gave him a 2000 lb dexter axle, and convinced him to move it back. The first load of wood he did,he was amazed at how much better the tractor pulled it out of the wood lot. For the previous 10 years or so, it had been lifting up the back of the tractor so much that he could not pull it with the 8n when it was loaded.
   / Seen on Craigslist #5
I bet that trailer makes the truck wobble from side to side all the way down the road, especially if it has any weight behind the axle.
I don't want to come off as snooty or something, because lord knows I have done some dumb stuff in my life, but it just astounds me that someone would take on the task of building a trailer without doing enough research to know that you can't just put the axle wherever the heck you want.
   / Seen on Craigslist #8
At least he is using red flags on his load.
   / Seen on Craigslist #9
Not that I would defend the person who decided to add that wooden bit on the end but it's not axle placement but weight distribution that matters. If you load pillows on the rear and lead on the front you would be fine.
   / Seen on Craigslist #10
The pickup bed trailer is fine. The axle is well back. You have to look at the total trailer length. Unless, as crazyal points out, you load all the weight aft of the axle, but there is quite a bit of steel in that tongue.
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
2013 Kenworth T800 T/A Dump Truck (A53117)
2013 Kenworth T800...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A53426)
2013 PETERBILT 386...
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
