Seeking info/advice pertaining to LS Tratctors
   / Seeking info/advice pertaining to LS Tratctors #1
Rustybolt
NH T4050
I would appreciate any replies concerning the LS Tractors. ie: Current or prior owners experience, Price, reliability, parts availability, Fuel Consumption, how long they have been established in the US etc.
I am considering something in the 40 to 50 hp range.
Thanks!
   / Seeking info/advice pertaining to LS Tratctors #2
Nothing but good to report open my LS. Had one issue with the loader valve, but dealer took care of promptly.
   / Seeking info/advice pertaining to LS Tratctors #3
Thanks!
You are going to hear a lot of good things on here about LS. They have been making tractors for along time under other names in the USA. They are priced cheaper than the competition. For me it was an easy decision. Lots of extras are standard on LS the other guys charge for.
   / Seeking info/advice pertaining to LS Tratctors #4
I have a 4041H. I am very happy with it, I only have 50 hrs on mine. Only prob I have had was a small coolant leak, the dealer took care of it quickly. I don't know about parts availability, I haven't had to order anything. Mine started easily all winter with out a coolant heater and we have had a really cold winter here. I have R4 tires , they did great in the snow and I plowed a lot this winter, the nice big wide tires on the front are very nice. The standard rear remotes was a big plus for me. I don't know much about the Tier 4 engines but if I was looking I would try and find a Tier 3 and buy it now. The only real problem I have is there is no good place to put a tool box. In my opinion, Good Tractor, good history, good reviews,Good price, above avg specs, and standard equip. = Best bang for the buck. Good luck.
   / Seeking info/advice pertaining to LS Tratctors #5
Thanks!
Might want to take a moment & just read thru the LS forum ... there are many threads and you will probably have all of your questions answered.
   / Seeking info/advice pertaining to LS Tratctors #6
I've had my R4047H for a bit over a year, and I've put about 175 hours on it....zero problems. As far as parts availability, I bounced my finish mower off a stump, breaking one of the 3pt stabilizer arms, and was able to get one in two days from the local Case/IH dealer by telling them I needed the same part for a Farmall 50B (same machine). A while later I was loading fill from a pile and found a large rock with one edge of the bucket...which caused a slight bend in the bracket on that side (everything still worked)...they are intentionally the weak link so you don't break something important. This time I decided to try one of the online suppliers, and had the correct part in 3-4 days. The only time I got worried was the first big cold snap after I got it, and I hadn't even looked at the manual for the cold start procedure (really it's just to put the throttle at about 1/3 rather than idle)....it makes a difference!
Is it perfect? No, I'd change two things, but they're not deal-killers for me. I sometimes wish the loader had 10-12" more lift height. It only comes up when I load my neighbors small dump truck, or the two times I loaded 30yd rolloff dumpsters, so it's not a huge deal. I can still load either, but it slows me down a bit. The other thing is I'd like a little more room between the left side brake pedals and the fender to make getting on/off easier. I don't even think about it now, but it would be a nice change.
LS is building compact tractors for New Holland, and Case, so that makes three different dealers you can get most parts from. NH/Case use their own loader, so that means you'd need to get loader parts from an LS dealer, or online supplier, but that doesn't seem to be a big challenge right now. My loader parts were drop shipped from the LS warehouse in NC, so it was pretty seamless.
Going off memory, LS has been selling under their own name since 2009, and started out as a division of Hyundai in 1975. As part of the LG family of companies, they have the backing of annual revenue that's essentially the same as John Deere. Many people think that because of that they're intentionally working on much smaller profit margins to gain market share, and then eventually crank up prices, and move into more sophisticated products. That's a similar model to what Hyundai did....start out with the less expensive machines, and now you can buy a $75K car from them. They're certainly expanding both here, and in the rest of the world....they opened a factory in China to supply machines there, and most recently one in Brazil to serve the South American market. I don't think we'd see that from a company that won't be around for a long time.
   / Seeking info/advice pertaining to LS Tratctors #7
Did you see this thread I posted a while back? Might be an option..
http://www.tractorbynet.com/forums/ls-tractors/256882-nh-b40-toolbox-kit-ls.html
   / Seeking info/advice pertaining to LS Tratctors #8
   / Seeking info/advice pertaining to LS Tratctors #9
I use a fuel caddy with an 12v pump so I fule from the side and keep an eye on the tractors fuel gauge. The box does impeded vision a bit but not too much.
   / Seeking info/advice pertaining to LS Tratctors #10
I bought a 4047 two years ago.
I have 175 hours on it with no problems.
My tractor use about a gallon an hour when working it.
The only two complaints that I have
1 the height of the FEL, but I have learned to deal with it
2 the strength of the three point links, have broke them a couple times
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A52748)
2023 NEW HOLLAND...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
