Seeking experience changing hydrolic fluid
   / Seeking experience changing hydrolic fluid #1
Thomasre
Bronze Member
North Carolina
Kubota L3430 + BX2230
I am ready to change my hydrolic fluid in a M4700 4wd with Loader. (Changed my oil yesterday, at 190 hours) Have purchased Amsoil oil & hydrolic fluid - I want any suggestions or experiences which might help. Can this be accomplished relatively easily? Suggestions? How about gear lube - easy change? Thanks in advance.
   / Seeking experience changing hydrolic fluid #2
Put the 3 point down, lower the loader and curl the bucket to get most of the hydraulic fluid back in the resevoir. (Search this site under 50 hour or M6800 and I described this process in detail several months ago). Basically get two 5 gallon buckets, remove the drain plugs (there will be 2 or more) and catch what comes out and be ready to put the second bucket in place. It is very easy to miss one of the drain plugs and then it will not drain or refill the correct amount. By carefully measuring what you drain you will find the problem before you refill it.
Remove the hydraulic cartridge filter (s). I had to clean the magnet that sticks into the cartridge filter although I did not see any filings on it. Drain the front axle. Mine also drained at the bottom of the front wheel gears.
The front differential does NOT come from the factory filled with gear oil(80/90W). I would not use gear oil, but replace the fluid in the front axle with the same UDT or Super UDT that I used in the transmission/hydraulic system. I used a small hand pump to refill, and carefully replaced the same amount that I drained out and then checked to be sure all compartments were refilled properly.
   / Seeking experience changing hydrolic fluid #3
Know how much oil should be in the transmission and plan what you're going to drain it into. My transmission holds over 5 gal, so I can't drain it into an empty pail without putting the plug back in (real messy). Fortunately that never happened, because there isn't clearance for a 5-gal pail under the tractor.
I used a 12-liter drain with a pour spout on the side. When the drain started getting full, I tipped it so it poured into a smaller pan, which I then emptied into a pail. I screwed the fill cap back in to slow down the flow while I emptied the small pan. I know, just buying a bigger oil drain would have been easier, but the local store didn't have one.
As Wen said, a hand pump to transfer the new oil is a real good idea. Trying to balance a full oil pail on your knee and pouring through a funnel won't be a good time. On my front axle, you'd have to have a gooseneck funnel. I bought a pail pump from Northern Tool. It's a metal lid with a pump in the middle that's designed to replace the lid on a standard 5-gal oil pail.
Also plan how you're going to get rid of the oil. It's easier to deal with in small quantities, and your local gas station may take it at his (in 5 - 10 gallon lots). We had over 400-gallon of waste engine and hydraulic oil from a previous owner pumped this summer. It's not easy to get rid of much more than 10-gallon at a time.
   / Seeking experience changing hydrolic fluid #4
My Kubota dealer allows you to bring all of your waste oil and hydraulic fluid to him in any quantity. He said from your car was ok too. He pays to haul it away, but does it as a customer service. The M4700 should have plenty of clearance for 5 gallon buckets and it is much easier to slide one bucket out and another under the drain than to mess with the drain plug.
Thanks TomG and WEN, You both have helped greatly, I used a 5gal bucket to drain oil - good clearence. Will do same for trans/hydrolics. As for front differential, I was interested that didn't come with gear oil(80/90W). Will check owners manual also. Thanks for info on multi drain plugs and action ("3 point down, lower the loader and curl the bucket"). Will be changing both hydrolic filters also. Since I purchased my tractor used, I'm not sure my local dealer will take used oil, I don't mind asking, I did buy $100.00 worth of filters (oil, hydrolic(2), fuel, air(2) but I'll check other places as well - will Advance Auto or Auto Zone take old oil in 5 Gal containers? Thanks again.
FYI- couldn't find previous detail of changing hydrolics when looking under M6800 or 50 hour. Maybe I just didn't perform search correctly. If you can point me to any additional info? Thanks again.
   / Seeking experience changing hydrolic fluid #6
"50 Hr Maintenance on M6800SD Tractor" is in Kubota Owning forum or search for 50 Hr Maintenance and you will find it. There are also some related posts in Oil and Lubrication Forum on the oil analysis results.
71058 (A49346)
71058 (A49346)
2002 EZ-Go 36V Electric Golf Cart (A51568)
2002 EZ-Go 36V...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
