Seeking advise far hydralic issues on ford 1910
   / Seeking advise far hydralic issues on ford 1910 #1
dadtkm
Fliny , Mi
Ford 1910
New to this site. If I seem lost I may be. Please be patient. Parked my tractor for about a month maybe longer but not much longer. hyd's worked fine when parked. after work was done on house I jumped on tractor to get it ready for winter and no hyd's. Changed the filter and the hyd's worked better than ever. Shut the tractor down took care of some chores. Went back the next day and the hyd's worked very, very slow. The next day nothing, no movement at all. Still had power steering though. Checked the pressure at the loader quick attach fittings it was 2300 PSI. Reattached the loader fittings and things worked again very slowly, loader and three point. That is where I am at tonight. Tomorrow I may have nothing at all again. Something I noticed, when I shut the tractor off after checking the pressure the engine stopped quickly. I restarted the tractor to make sure that is what the engine was doing and it did stop quickly. After I reattached the loader hyd's the engine stopped normally, it still spun over a few times after the engine was shut off. I hope this makes a little bit of sense to someone. It's bound to snow some day and I might need this tractor. Thanks for any ideas and help, it will be appreciated very much.
   / Seeking advise far hydralic issues on ford 1910 #2
:welcome: to TBN
Be sure 3 pt hitch control valve is in neutral IE not continuing to try to raise up 3 pt causing relief valve to open
Oster Pipe Threader (A49251)
Oster Pipe...
2025 Swict 84in Bucket Skid Steer Attachment (A49346)
2025 Swict 84in...
Grove 4x4 Rough Terrain Hydraulic Crane (A49346)
Grove 4x4 Rough...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2009 Westfield MK 100-71 (A47164)
2009 Westfield MK...
Ford Explorer (A46684)
