Omega Woods
Platinum Member
- Joined
- Mar 7, 2016
- Messages
- 610
- Location
- Soddy Daisy, TN
- Tractor
- Branson 4520R, Kubota BX2380, Kubota RTV-X110C, Bobcat E50, ASV RT-50
I have a 2015 Branson 4520R with hydraulic steering. This morning when I went to do a little cleanup work around the place, I noticed that the steering was very heavy. This is normal for cold startup but it didn't seem to get better after a few minutes. When I stopped, I noticed a two drop per second leak from the left end of the steering actuator cylineder so obviously the seal has let go and needs to be replaced.
What would you advise? Replace the seal, take it to the hydraulic shop or get a new cylinder? I am capable of removing it from the tractor and reinstalling it with no problems, everything is readily accessible. Once I get the cylinder work done, are there any special precautions I need to take when putting it back on? Does it need to be bled or filled? I've done a lot of different work with lots of mechanical systems over the years (Navy, Power Plant mechanic, industrial maintenance guy, etc) but my knowledge of hydraulics is limited and I want to do it right.
Thank you and Merry Christmas!
