Seeders Seeder
   / Seeder #1
heitjer
Bronze Member
Houston, TX
LS R4041 & LL4100 FEL
Hi,
my friend and I need to plan for spring and want to seed pasture out. We have 6 acres and 4 acres to seed. What would be your suggestion for an appropriate attachment for this job? We have looked at the three point and pull behind seeder and spreader.
The initial thought was to buy a 3 point spreader. I like to pull behind as well but question the stability due to small stance.
Any thoughts? Much appreciated!
   / Seeder #2
cone spreader then rake it in works for me. any other way requires a drill.
   / Seeder #3
Hi,
A brillion seeder is the perfect tool for the job,
I would just rent one though as they cost to much to purchase just to use on 10 acres.
   / Seeder #4
You might want to hire the job out. I had a custom farmer apply seed on about 10 acres of pasture. He had a much larger tractor (than mine) and a no-till drill. He did a good job much faster than I mow the same area. The seed companies in your area will have recommendations.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
2005 Sterling Acterra Tender Truck (A57024)
2005 Sterling...
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
