Securing Hydraulic Lines
   / Securing Hydraulic Lines #1
Mike058
Key Peninsula, Wa
Kioti CK3510SE
I have to take a cylinder from my grapple in and have my dealer fix a pinhole leak. Getting it off looks pretty straight forward, but I'm wondering what I need to do to the open ends of the hydraulic lines. I don't know how long they'll keep it and I don't want water, dirt, bugs or whatever getting in while the lines are disconnected.
   / Securing Hydraulic Lines #2
I just put plastic sandwich baggies over the ends and secure them.
   / Securing Hydraulic Lines #3
^ +1 plastic baggie with a wire tie or a rubber band
   / Securing Hydraulic Lines #4
The best solution, especially for longer term, is to buy hydraulic fitting plugs to seal off the open fittings. Starting at CDN$2.99 you won't break the bank and you can keep them in y tool box for when you need them later.
Your local hydraulic shop can help you.
If you are in the habit of buying hydraulic cylinders and hoses often they will come with plastic plugs you can re-use. I tend to save them and keep them in a fittings drawer for such times when I need something.
Thanks for all the ideas. I appreciate the help.
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
New/Unused Quick Attach 72in Skid Steer Mulcher (A51573)
New/Unused Quick...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
