Securing hydraulic connections
/ Securing hydraulic connections #1
jloven
Bronze Member
Marshall, NC
2013 John Deere 4720, 2014 New Holland T5.115, 2017 JD 4066R cab
I wanted to see how others were securing their hydraulic connections... I had the lower threaded connection on my QC female for the power beyond vibrate loose?? Not sure why it came loose but it did and fluid started flowing out at a fairly high rate. Probably lost a gallon before stopping tractor. With its location, the lower connection is difficult to access. In fact, I had to remove the upper QC on the power beyond just to get a wrench on the lower female nut. Does anyone use any type of thread lock on such connections? Its an 1-1/4" nut, so wasn't sure if thread lock would even hold it. I tightened it as best I could but power beyond hose gets rotated, it could possibly happen again. Any suggestions? Thanks
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
Screen USA CF35D2 Tri Axle Towable Trommel Screener (A61572)
Screen USA CF35D2...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
