Secure Set
   / Secure Set #2
I think the post will still rot from the bottom? In the video they don't even show any rock or drainage in the bottom of the hole. I would rather have some kind of post protection in addition to the Secure Set. The product seems to be a pretty good application instead of concrete. Good luck, let us know how it went if you use it.
   / Secure Set #4
Tech sheet on their web site says the compressive strength is either 85psi or 140psi depending which product you buy. Those values don't get you anywhere close to supporting the lateral load you need on a pole barn. I can't understand how this stuff can be used for power poles and steel poles. Concrete has a compressive strength of 1000s of psi depending what mix you get. Soil will generally take somewhere between 1000-5000psi loading, so I can't see how this stuff wouldn't just get squished. Maybe I'm not understanding their spec sheet...
2013 CATERPILLAR 312E EXCAVATOR (A51406)
2013 CATERPILLAR...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
Deer Gates (A53424)
Deer Gates (A53424)
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2016 CHEVROLET 3500HD SERVICE TRUCK (A54756)
2016 CHEVROLET...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
