Second tractor vs upgrading current tractor
   / Second tractor vs upgrading current tractor #1
WVH1977
Platinum Member
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck
I am getting ready to build a new house on our new property (16 acres) this fall. I just cleared three acres with a mini-ex and I am currently fine grading it with my tractor. Here are some pics of the ongoing job. IMG_0472.JPGIMG_0474.JPGIMG_0482.JPGIMG_0485.JPG
I plan on buying a new tractor once we start building the house. I have looked at several 44 to 60 HP CUT's that are really nice and $$$$$. I have also looked at several SCUT's that are nice and less $$$$$. This is where my dilemma starts.
1st Option:
If I decide to go with a newer CUT I will have to sell my current tractor (NH TC40) and use that for the down payment. Plus side on this is I already have all the six foot attachments and buckets needed for the newer machine. I almost sold my tractor a couple of years ago to upgrade but could not part with it. It has 485 trouble free hours on it. If I buy the new CUT I will more than likely go with a cab model.
2nd Option:
I buy a SCUT (TLB with MMM) for working around the three acre yard and house. I will keep my current tractor and use it for the bigger jobs around the property.
If you all were in this kind of situation which option would you lean towards? Right now I am leaning more towards keeping the current tractor and buying the SCUT as a helper. All replies and opinions will be appreciated. One more thing, I will post about the machines I am looking at in another thread for thoughts and comparisons.
   / Second tractor vs upgrading current tractor #2
You have a trouble free 40hp tractor. Why would you swap it for another?
   / Second tractor vs upgrading current tractor #3
What jobs do you see that your current tractor wouldn't be capable of?
I will say that three acres is a bit much for a SCUT to mow, it'll do it obviously, but you'll spend more time than I'd want to doing it. A zero turn is a far better tool for mowing actual lawn, and a decent used commercial one can be had for not much more than a MMM for a SCUT.
   / Second tractor vs upgrading current tractor #4
If in no hurry to purchase and TC40 doing well hold off until new house built and grounds are shape the way you wish...things change.
I currently have two zero-turns, a Gravely and a Scaggs so I probably don't need the MMM. Just thought it might be nice to have for a just-in case.
The only reason I am considering it is to get into a cab. Right now I am fine without a cab but I am getting older and there are times I wish I had a cab.
   / Second tractor vs upgrading current tractor #7
We have 30 acres and my old Kubota L2900 (30hp) was just not enough tractor and I had to mow upwind since the Kubota was open station. I'm no youngster and I love my cab 4720 Deere, it's fun now to do anything with the tractor. It gets expensive when you need to also upgrade implements but in the long run it's well worth it.
   / Second tractor vs upgrading current tractor #8
   / Second tractor vs upgrading current tractor #9
I live on 20 acres and have an additional farm of 150 acres. My only cab tractor is an old TLB that I just bought. What tasks are you going to be required to do on 16 acres that also require a cab?
   / Second tractor vs upgrading current tractor #10
I can't help with the "add or replace" question, but I will say that going from my open station JD750 to my cabbed B2650 is the best move I've made in a LONG time. The cab, heat and A/C takes any discomfort out of the equation.
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
378569 (A51573)
378569 (A51573)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
2014 INTERNATIONAL DF677 (A52472)
2014 INTERNATIONAL...
