Brent.Roberts
I have been cursing the designers of the BX-23 for some time now. It seems they decided only children under 2 and gremlins should drive a BX.
the seat cover is neatly tucked into the moulded plastic shell with a bit ( not enough ) foam in between.
When any normal person sits on it, the air in the foam needs to escape.
The "design engineers" evidently did not think of this, so the seat cover blows itself out of the retaining trim. You can put it back but the next time you sit on it it will blow out again.
Did they catch up to this problem on the more recent models. If not you (we) need to drill holes in the seat to let the ( hot ) air out, hopefully somewhere that will not let the rain in when it's tilted.
