ritcheyvs
Veteran Member
I have a Sears lawn tractor with 8 year-old Carlsile 20-8x8 rear tires that I'm trying to replace. These original tires are dried out and they leak from cracks in the sidewall. Slime stops the leaks but I figure they really need to be replaced. I bought a set of 4-ply Duro tires via E-bay and they look OK except the beads are very close together (maybe 4 inches) and I cannot get them to seat on the wheel rim, which is 7-8 inches wide. The tires will easily flex to fit the rim but the natural set is too narrow. I tried using a cargo strap around the tread but that didn't even get close.
Currently, I've pulled the tire beads apart and blocked them open to see if they will take a set in that position. I'm hoping they will stay spread until I can snap them over the rim and put in some air, but I'm not confident this will work.
So ... I'm looking for some backup ideas on how I can get these tire beads seated on the wheel. Thanks in advance for any inputs.
