Seat switch bypass
   / Seat switch bypass #1
aarolar
Platinum Member
Augusta Ga
Kubota MX4800
Is there a simple non evasive way to bypass the seat switch? Whenever I get on a slight grade I can't stay in the seat well enough to keep it engaged and it's highly annoying. Today I was mowing round the pond and if I tried to look back to watch the mower I just couldn't keep the seat down too light in the pants I guess.
   / Seat switch bypass #2
I unpluged mine at the HST "neutral" switch. It's on the HST pedal linkage on the Left side under your feet. Do it at your own risk (of theoretical actual harm and safety police assault).
Ill try to take a picture tomorrow. Super easy and reverasable.
GST here so may or may not be helpful.
   / Seat switch bypass #4
Oh. OK.
The actual seats switch is 3 position. Full pressure (seated), neutral pressure (empty seat), and no pressure (flipped up).
I THINK you'll find that in full pressure the swich is completely open. If this is true, then disconnecting the switch will simulate the seated position all the time.
If this is not correct then trial-and-error jump the non-black wires to the black wire until correct. (sould just be 3 wires)
My problem was that I'd lean right to see the loader better and trigger the safety.
   / Seat switch bypass #5
On my 5240 I unplugged the seat switch and put a jumper in.
Oh. OK.
That's the same thing I'm doing. I can't even take my phone out of my back pocket without it studdering.
   / Seat switch bypass #7
Take Coke can and cut strip to size needed to hold down switch.
   / Seat switch bypass #8
On my BX2230, I just buckle the seat belt ove the seat to keep the seat down.
   / Seat switch bypass #9
Thick chunk of rubber or a wooden block wedged between the mounting bracket that holds the switch and the switch lever works, that's what's on mine. Safety devices are a pain in the a**
   / Seat switch bypass #10
Has anyone done a B2620? I only have clamp on bucket forks and you can't see them while seated.
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
YARD MACHINES MOWER (A50854)
YARD MACHINES...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A51039)
2006 Magnolia Dry...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
