Seat Repair on JD 870?
   / Seat Repair on JD 870? #1
TerryR
Veteran Member
Boone, NC
JD 870
My 18-year old JD 870 has been parked indoors most of its life, but the seat has finally begun to show its age. The vinyl cover is still sound, but the u-shaped edging that holds it to the steel body is coming off. I've tried to re-seat it but after an hour or two it pops off again.
Has anyone had any luck re-installing the edging on this type of seat and making it stay?
Terry
   / Seat Repair on JD 870? #2
I used pvc pipe glue on my mower seat , worked great .
   / Seat Repair on JD 870? #3
Google "upholstery edge trim", you should be able to find a suitable replacement.
   / Seat Repair on JD 870? #4
I used Gorilla Glue and a 50 bag of sand as a "clamp" while the glue set. Worked good for me...
Thanks, Guys,
Sounds like I know how to approach it - Gorilla Glue and/or new edge trim.
Terry
   / Seat Repair on JD 870? #6
I used Seal All for the edge trim. I also had rips in the seat. I cut vinyl patches and glued them on with Seal All. It's held for years.
2020 RoGator RG1300 Air Max Precision R2 Spreader (A53342)
2020 RoGator...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
STORAGE FEES (A52576)
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
