seat height in D series
   / seat height in D series #1
mike123
Bronze Member
Saskatchewan,Canada
Toolcat B 2004
I went and test drove a D series today to see how it compares to my B model. One thing I didnt like, I can barely reach the pedals comfortably and I am not that short. I don't know how anyone shorter than me could even drive it.
MIke
   / seat height in D series #2
The seat is indeed high, I assume you had it moved all the way forward?
DEWFPO
   / seat height in D series #3
the rails are not on a slope either so as you move it foward it no longer lowers!
not good for my 4'11" wife.
what I dont like is the flat bottom. it gets stuck if you look at it funny in the snow. plus with the engine under the cab its louder inside, and doesnt feel as stable with a load on the forks.
i like the power of the turbo, but wish i would have kept the old one.
Yes I had the seat forward. I don't know if I would have noticed how terribly uncomfortable it was if I didn't already own an earlier model.
   / seat height in D series #5
I am 5'8"-5'9" and don't mind the seat height. At first, I also thought it was a little on the tall side but now it seems more natural. Tall seat helps the visibility for the 3 pt on my 5610. When I get on my JD 4520, I pump up the air seat to make it higher and like the taller seat height. I think the high seat is due to the larger capacity of the fuel tank.
The clearance on the D is 9" with the larger tires. Not the greatest. My prior JD 3720 had about a 10" clearance at the drawbar/transmission. I also have a skid steer and the clearance on that is also marginal. I have learned not to go in deeper snow with the TC or skid steer. It will cause too much drag and I have been high centered. I have learned to dig, plow or blow my way through snow and keep any residual snow under the height of the spine frame of the TC. Part of the problem is the tread design which IMO, is poor for traction on the TC. It needs an R1 lug design option. What was the clearance on the older TC series? The older design didn't seem to have much clearance either.
I don't think the noise in the cab is any greater than my prior cabbed JD 3720 or my current JD 4520. I also have large ag tractors with cabs. The noise is very acceptable in all. There is considerable sound insulation between the motor and cab. If you want bad cab noise, drive a Kubota 1100 RTV. The noise is terrible and unbearable IMHO.
Stability with forks is a non issue for me. Vastly more stable than a CUT with a pivoting front axle. I modified my lift arm cylinder and can lift nearly 3000 lbs but rarely do. Don't worry it is stable. It may seem a little unstable due to the give in the rubber stops on the suspension. You have to love the smoother suspension of the D series.
   / seat height in D series #6
had a c and now a d. it is definately louder in the cab - i use earplugs now and don't bring the kids anymore. i also dont like the seat in the d - the c was softer and more comfortable angle (and i am 6'2"). on the flip side everything else is better, especially the ride. also no overheating issues at all.
i think the d gets stuck less easily than the c but that may have a lot to do with the larger tires.
my 2 cents
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
2000 Dnya RGN T/A Trailer (A49461)
2000 Dnya RGN T/A...
3in Poly Pipe (A49461)
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
