3-Point Hitch seat cut off switch prevents use of chipper
   / seat cut off switch prevents use of chipper #1
CWB
southwestern CT
B3030, BX25
I just bought a chipper for my BX 25. It works very well except that if engage the PTO power then get off the seat of the tractor, the engine stops. How does one avoid this issue?
   / seat cut off switch prevents use of chipper #2
Try getting off the tractor, flip the seat forward onto the steering wheel, then start the tractor and engage the PTO.
   / seat cut off switch prevents use of chipper #3
My BX24 manual says to turn the seat around rearward when using a chipper.
   / seat cut off switch prevents use of chipper #5
It must be something in the water here. I just finished putting together a BX42 on my L3400 and even though I knew about the seat switch I still got off 3 times today & inadvertantly shut it down :(
   / seat cut off switch prevents use of chipper #6
If your tractor operates the same as my BX23, you only have to release the seat latch. No need to turn it around.
thanks all - I will try it - and appreciate the quick responses
   / seat cut off switch prevents use of chipper #8
Train your wife to feed the chipper so you don't have to get off the seat.
   / seat cut off switch prevents use of chipper #10
Before i bypassed it:ashamed:,i stuck a cedar shingle in it ,while running my chipper.
ALAN
2016 Ford Fusion (A50515)
2016 Ford Fusion...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
John Deere 1020 Tractor (RUNS) (A50774)
John Deere 1020...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2018 TAKEUCHI TB210R EXCAVATOR (A51242)
2018 TAKEUCHI...
