seat control?
   / seat control? #1
schmism
Super Member
Peoria IL
New holland TC(33)
it sounds like a stupid question i know but....
So im helping a friend on his farm and on his T190 (ish)
The lever that you use to adjust the forward/backward position on the seat will not move.
What is the intended direction of the movement of the lever? pull up? push down? pull out?
   / seat control?
seriously? no one knows off the top of there head the direction you have to move the lever to get the seat to move?
The offending lever is frozen so in an attempt to get it unstuck, i at least want to know that im forcing it in the right direction!
   / seat control? #3
Lets TRY some LOGIC, if the lever is on the right hand side of the machine then the act that is easy for the human arm to move is backwards to release the latch.
Craig Clayton
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
UNUSED LANDHERO LDHGAC40V AIR COMPRESSOR (A51248)
UNUSED LANDHERO...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
