Seat bolts 3000 Ford ?
   / Seat bolts 3000 Ford ? #1
Down South
Long 360
I am changing a seat on the neighbors 3000, What have I gotten myself into?
1 is a 7/16ths bolt, the other is a 3" long stud, then 3/4" 7/16, then 1/2 collar, then a 1/2" fine thread stud.
At least that is what i think it was Once upon a time.
What does the stud do? Do I need it or can i just replace it with a standard bolt?
DS
   / Seat bolts 3000 Ford ? #2
you've managed to pull out a locator dowell for the draft portion of the 3pt hitch.. :)
position control should work fine...
if possible.. I'd leave it in.. :)
How long should it be?
I imagine things are out of position already, as the old seat was replaced 10-15 years ago, when he bought it.
This one is maimed on both ends and the middle, This one couldn't hold much.
I am not sure i can get the big nut off with out the torch, 7/16 fine and rusty/ corroded threads.
At least its the rear bolt.
DS
   / Seat bolts 3000 Ford ? #4
if it's gone it's gone.. no biggie.. position control will work fine.
Cool
He was asking me about machining down a bolt to replace it.
You know about even older farts than me getting stuff done for free.
DS
   / Seat bolts 3000 Ford ? #6
grinding down a bolt would work.. :) btdt.. :)
ROME AH-240 LOT IDENTIFIER 117 (A53084)
ROME AH-240 LOT...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
HURRICANE 40' CONTAINER (A51248)
HURRICANE 40'...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
2010 Ford Crown Victoria (A51694)
2010 Ford Crown...
