Sears Craftsman Problem
   / Sears Craftsman Problem #1
Scolb
Hey all. I have a 2001 sears craftsman riding lawn mower (42 inch cut) and just recently, I have heard a grinding noise and noticed the belt smoking around the front engine pulley. Just to give some further details, the grinding, screeching noise started first as I was driving. And then it would quit. After doing some regular maint. on the mower, I changed the lower belt out and when I cranked it, it ran fine for just a few seconds and then the grinding noise started again along with the smoke. This happened with the mower in neutral and the blades not engaged. What could be happening here?
   / Sears Craftsman Problem #2
I would check the idler pulleys. They tension the belt for blades or driving. Those get rusty and crud in them after lot's of use.. Sometimes if the belt is worn and loose that will cause the same problems
   / Sears Craftsman Problem #3
Treemonkey1000's advice should put you on the problem. The best advice I can give you is that if it has an engine or a wooden handle do not buy it from Sears.
2011 John Deere 120D (A47477)
2011 John Deere...
2022 CATERPILLAR 302.7 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
