How do I remove the blade assembly from the briggs output shaft? The retaining bolt came off easily and wasn稚 rusty. However, I have not been able to remove the blade assembly. I have tried using bearing pullers with no success. Have heated the blade assembly where it slips on the shaft while applying pressure with the bearing puller and still no success. Help would be appreciated.
The long story is that the crank shaft bearing has failed and i need to remove the blade assembly in order to determine whether the motor is repairable.
