pat32rf
Veteran Member
Not for my tractor but rather my trailers....I'm gradually switching my trailers from the normal lights with bulbs to the round sealed units that mount in rubber gromets. I've found that they last a lot longer than bulbs and I don't have corrosion problems.
There is however a very fine line between cutting the hole too large (things fall out) and too small (things just won't fit without using a prybar).
Does anyone know what the diameter of the hole SHOULD be?
I have these lights on my ATV trailer and they have lasted for years now I want to change another two trailers to them....They are cheaper than buying a trailer lite kit at Camnadian tire as well.(as long as you don't pop for the LED version)
