Seal assembly
   / Seal assembly #1
Deerlope
Veteran Member
Northern, New York
Kubota L3830 03: RTV 900
Has anyone ever put a shaft seal in a mid PTO unit on a Kutoba? If so, how diffcult is it to do. I know that I have to drain all the oil because this is the lowest point in the system. I don't have a good illustration break down of the unit.
   / Seal assembly #2
<font color="blue"> don't have a good illustration break down of the unit. </font>
Speaking as a non-mechanic who has tackled many mechanic type jobs on my tractor--get the service manual and parts cataloge before you dive in. One do-it-yourself project like this will pay for the manuals in the labor cost you save, and they will provide the "good illustration" that you need. Good luck.
OkieG
   / Seal assembly #3
I just did the one on my Cub Cadet. I know it is not a Kubota. I would think they would be quite similar. I did not drain the oil in the case. I only lost about a pint from changing the seal. I popped one out and the other seal right in., The fit on mine was not extremely tight. I was able to use a chisel and get behind the seal lip and it came right out. I used a large socket to put the new one in. I believe the lack of lost fluid is due to very small oil holes to feed the mid-pto. Otherwise a seal failure would dump 5-10 gallons of fluid in minutes.
Woven Landscape Fabric (A53117)
Woven Landscape...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2006 BIG TEX 16 T/A TRASH TRAILER (A53843)
2006 BIG TEX 16...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
