SD2043
   / SD2043 #1
rightsideinlet
La Marque, Texas
Shibarua SD2043
Hello out there everyone! I was looking for some advice on a hydrolic problem I am having with my Shibarua 2043. Front loader is working great but, the 3 pt has always been a bit slow and lethargical. Past several months it would raise and then go down super slowly. Now it just quit working. I pulled the control box off and found that mice had gotten in there and made a nest chewing on some of the wires. I fixed the wire but, still nothing so I found that the control of the 3pt is via two selinoid valves. I was able to pull the one out and take a look at it to clean it up and it looks fine. The other one is a bit of a job to get out. Anyhow I would not mind switching this thing over to a regular control valve like my front loader if possible. Anyone have any suggestions? or have any of ya run into this problem before? It's been a pretty solid tractor the past 8yrs. Thanks
   / SD2043 #2
I get a lot of calls on electric over hydraulic not working. Converting to manual controls is a viable option. But without physically having the tractor it is hard to tell you how to do it. Usually when I get the tractor it isn't working right & it is hard to determine the hydraulic circuit. You'll need to remove the control valve & determine which passages the oil is supposed to go with the valve in different positions & make a manifold so you can hook up the hoses to the valve correctly.
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
GAS BUSTER FOR FLARE SYSTEM (A50854)
GAS BUSTER FOR...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
