SD1843 Shibaura 4WD Hyd Lift does not maintain lift position
   / SD1843 Shibaura 4WD Hyd Lift does not maintain lift position #1
RED2852
Kernersville, NC
Ford Jubiilee
I don't own this tractor but am trying to help someone that does. The lift system will raise to the selected height, but will slowly drift back down even while the tractor is in operation. I don't know the details of the lift system but it sounds like whatever mechanism is used to maintain the lift position, it is allowing fluid to leak down from the setting. Has anyone experienced this before and was able to fix the problem?
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
John Deere 650K (A53314)
John Deere 650K...
ASCO Transfer Switch (A52377)
ASCO Transfer...
