SCUT or CUT.....that is the question!
   / SCUT or CUT.....that is the question! #1
mahd776
Cuba, IL
JD GT275
Looking to purchase a first tractor other than a Garden Tractor. My primary residence is a lake front ranch that sits on maybe 2 acres. Mow with one or the other of the JD Garden Tractors that I have with 48 inch decks and takes about 2 hours. Yard is generally flat for most part with quite a few low spots scattered about. One of the jobs I want to tackle is leveling those spots and seeding. Also want to put in some more landscaping flower beds as well as work on and improve ones we already have. Our largest is 120 foot long by 4 foot wide. All our currant flower beds need more soil or mulch added. Want to improve surface drainage around house foundation by adding soil. Have a sidewalk that needs torn out and replaced and a area where I park a utility trailer and a boat that I need to whiterock.
In addition to the primary residence my brother and I have a 55 acre deer hunting area about 30 miles away. We usually mow around our trailer several tines a year and transport our Garden Tractors to do that. In addition there is about 8 or 9 acres of the 55 that are open grass field. One of the fellows that hunts with us usually mows that with a pull behind ATV mower once a year. So I have started looking at purchasing a smaller tractor with a FEL, MMM and a rotary cutter. Unit needs to be small enough to be handy at the primary residence and capable of doing what I want to do there. At same time want to do work at the deer camp. Mowing around trailers should not be a problem of course. The 8 or 9 acres of grass and weed field I want to mow more often hence the rotary cutter probably a 48 inch model. Have a gravel access road to blade once in a while and possibly move some dirt to build a shooting backstop. Looking for advise on tractor size. Small enough for around house use but still capable of doing what I want at the deer camp. Have looked a bit at JD, Massey and Kioti. Have not looked at Kubota yet. I am going on 68 years old and I am retired so time is not a factor in getting things done as quick as possible. Am getting to the age a shovel and wheel barrow is not much of a option anymore. SCUT or CUT. Looking at new but used is possible. Really like the JD 1025R and Massey 1715 in new models.
   / SCUT or CUT.....that is the question! #2
Go bigger than the 1025R and 1715. The lack of ground clearance and tiny wheels will be problematic at your hunting property. Tiny wheels fall into every small hole and make for a rough ride. They're not much more machine than your garden tractor.
2 series Deere at least.
   / SCUT or CUT.....that is the question! #3
I agree that at CUT would be better for the bigger mowing and land maintenance but you seem to want a mid mount mower and those are not as easy to get on a Cut. Also remember you have to transport this thing so do you have a vehicle big enough to take the trailer and tractor you want to mobilize? A small CUT with FEL will probably be near 4000 pounds without attachments. Closer to 5K with them.
   / SCUT or CUT.....that is the question! #4
I have neighbour's with both machines - each one loves theirs. I think the Massey is a 2015 and the Deere was bought last year.
The Massey is a really nice machine and looks solidly built more like an ag tractor with beefier looking castings. From what I've seen the small Deere's are built more like homeowner duty garden lawn mowers with more stamped sheet metal and welded parts. Take a good comparison look at the front axels, loader frame mounts, and 3PH.
It shouldn't really be that much of a difference but I'm a little biased after the Deere neighbour brought his machine over last summer on a long weekend for me to re-weld one of the mower anti-scalp wheel brackets that fell off on him. Cold lap weld joint. Should have been a warranty repair on his new machine but he didn't want to wait a week to arrange for the dealer to pick up, fix and return the machine.
If it were me I'd be probably be putting my money down on the Massey SCUT over that Deere model.
On the larger CUT's both are good brands.
When I was typing this at 1:00 in the morning it was in paragraphs. In the course of editing my laptop started rearranging things. Probably a setting of some sort but it was late and decided not to fight with it and just posted it. I figured, like myself, if anyone wanted to contribute constructive advise on the subject would just read it and do so.
   / SCUT or CUT.....that is the question! #6
In my mind, bigger is always better but, with a small property and transport issues a SCUT seems to be what would work best for you on the two acres, but you would certainly be better served by a good CUT on the hunting property. As already mentioned, make sure you have a means of transporting it properly - no compact pickup trucks here, you need a towing vehicle with some grunt, and at least a 16' trailer with dual axles and brakes all around.
I do have a 3/4 ton Ford diesel pickup and a 20 foot double axle utility trailer with brakes. Rated at 7000 lbs so hope transporting to land and back would not be a problem.
To those who choose to contribute to helping me make my decision I thank you! Looks like heavy in favor of a CUT over a SCUT.
   / SCUT or CUT.....that is the question! #10
I live not to far away near Macomb, Il. I have a Kubota BX which is a SCUT, but I agree, a CUT would be better for your other property. I'd also get a bigger brush hog than a 48". A 5 or 6 foot wide one will cut a lot faster but you also need the horsepower to go with it. A SCUT would work for you but like already said, the small tires make it not as good on rough ground.
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
90018 (A48082)
90018 (A48082)
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
