Screwed up....
   / Screwed up.... #1
Rowdius
Nugent, Texas
Kioti CK35 With KL130 Loader
Well, I may have went and did it today. The battery on my truck died while I was at the back of my property, so I hiked to the front, got on my 1500D and tried to jump the truck off.
I wasn't getting the results I wanted, so I left the jumper cable hooked onto the neg. terminal of the battery and moved the positive over to the solenoid (#8 on the picture here )
It sparked a bit, and I quickly took the jumper off.
Now the tractor will not start. When I turn the key I can hear a single click from around the starter/solenoid, I think. Using a knife to try to start it at the solenoid produces a spark, and maybe a click (cannot remember now, dang it.) I do not think the battery is low, but when I have light tomorrow I will lightly tap on the solenoid to see if I can unhang it (if it is hung) and perhaps bring the battery up to the house to charge.
If you had to guess, what would you say is wrong with it, and how to go about fixing it? A new solenoid is $50 before shipping.
   / Screwed up.... #2
Sounds as though you have a bad contact to the ground on the Tractor. Dirty or even slightly corroded grounds at the battery and frame can cause this?especially after a big surge, as when you try and jump start something.
Mark
   / Screwed up.... #3
If the tractor battery is a small one chances are you now have two dead batteries.:D
   / Screwed up.... #4
I'm thinking low battery, or dirty connections also. Start simple. I've been burnt many times by dirty battery connections (ground to block or otherwise) that "looked" clean. Even if it looks clean, clean it anyway.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
Caterpillar 200 Forklift (A53117)
Caterpillar 200...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
