screw driver inside tubeless tire
Status
Not open for further replies.
   / screw driver inside tubeless tire #2
i've found various things in tires.
if I know it's in there.. I get it out.
   / screw driver inside tubeless tire #3
I drove one through the face of a tire. It was one of those ones that you pull out of a handle, one end for flat, the other for phillips head. Darn cheap junk cost me a tire. Sure wish I could return it to its rightful owner.
If they left it in when changing the tire it wouldn't do any great harm but the sound would be there if you listened closely. Personally I wuld take it out.
   / screw driver inside tubeless tire #4
I've heard of putting golf balls, and sand in tires for balancing, but never a screwdriver.
   / screw driver inside tubeless tire #5
If nothing else, the screwdriver unbalances the wheel/tire. I would remove it and rebalance the tire.
   / screw driver inside tubeless tire #6
IMHO.. that was some rednecks bead breaking tool.. :)
   / screw driver inside tubeless tire #7
Easy now!! I've changed many a tire with only large screw drivers.
   / screw driver inside tubeless tire #8
I like to use a crow bar when the tire spoons can't get enough leverage. I would get that screw driver out of there. It will scratch the rim and wear at the inside of the tire causing early failure.
   / screw driver inside tubeless tire #9
I wasn't discluding mysaelf fromt hat statemnt either.
I've changed many a tire with a large c clamp and a brig screw driver too. that's how I know they can end up in there ;) ;)
   / screw driver inside tubeless tire #10
This may be dumb question. But why would you balance a tractor tire? Unless someone added some weird tractor tire weights to only one sector of a rim. I just don't see the need. They don't spin fast enough.
Status
2022 Caterpillar 906M Compact Wheel Loader (A50322)
2022 Caterpillar...
2015 Ford F-150 4x4 Pickup Truck (A50323)
2015 Ford F-150...
JCT 84" Rock Grapple (A50121)
JCT 84" Rock...
Frontier SB1107 3pt Sickle Bar Mower (A50774)
Frontier SB1107...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
