Scrape Blade Repair + plow bolt deal
   / Scrape Blade Repair + plow bolt deal #1
Brad_Blazer
Veteran Member
Caldwell Co. NC
2006 Kama554; 92 Belarus 250AS
My buddie's son inherited an 8N with some implements. The scrape blade had a broken pivot tube with all kinds of junk "welded" to it. It was separated from the frame and cracked. Another friend with a machine shop had a length of 3-1/2" sch 80 and he cut me a piece of it and slit it the long way. I had to spread it a little to get it to fit the 3" OD tube mounted on the blade, then used some 1/4" round stock to space the halves apart for a good fit. I welded everything with 6010 or 6011 on the first pass and then laid on some 5/32" 7018. Cut new 3/8" thick gussets to replace the wimpy 1/4" OEM ones. Seemed to turn out pretty good but it doesn't want to spin 360. I figure it will loosen up once the blade is put back on and the tractor works on it. If you notice some hammer marks on the welds that was from my attempt to loosen it up a little. I did add a grease zerk to help it move and help prevent rust in the pivot.
When I was taking it apart I cut the plow bolts off because the blade is due to be reversed. Went to TSC last night and they no longer carry plow bolts. Searched around online and it's pretty hard to find a good deal. Agri Supply has a good price but their shipping was more than the bolts. Found Zoro Tools and they had a 10-pack of 5/8-11 x 2" with nuts for $6 and free shipping!
Zoro Tools Industrial Supplies
I hadn't run the SA200 in about a year so it was nice to have a good excuse to fire it up.
   / Scrape Blade Repair + plow bolt deal #2
Sch 80 pipe may not have been the best material for this project. The pipe is made from mostly scrap material and greatly varies in it's physical properties. It is only designed to hold internal pressure so some batches will be brittle and some will be very ductile.
I hope it holds up but do be too surprised if it doesn't.
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
Rhino V152 (A50121)
Rhino V152 (A50121)
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
Polaris 90 Sportsman 4-Wheeler (A50121)
Polaris 90...
Ingersoll Rand 2570 Skidloader Breaker (A50774)
Ingersoll Rand...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
