Scotts(John Deere) S2554 Back up and Brake problem.
   / Scotts(John Deere) S2554 Back up and Brake problem. #1
tkcenterline
Scotts (John Deere) S2554, 25hp v twin kohler, 54" mower deck
I just bought a used Scotts (John Deere) S2554 lawn tractor 25 hp Kohler v twin, 54" mower deck. This tractor is in great shape. But, the mower, pto engine interface has a problem. The engine runs find in low and high RPMS as long as you do not start up the PTO (mower). When you pull up (on) the PTO switch, at low RMPs, the engine runs and the mower runs. At high RMP the engine will not run and wants to die out. However when you push on the brake pedal with the pto on, the engine and mower run perfect. When you release the brake, the engine wants to stop running. When you have the PTO on and go in reverse the mower still runs and is suppose to stop. The seat safety switch doesnt work either. It is like the safety features are not working properly. It seems that the brakes safety feature is working in reverse. So again, when the brake is held down the engine and mower fun fine. Release the brake and the engine doest run and almost dies. Push in the PTO (Off) and the engine run fine again. At first I thought it was the Gas pump. So I replaced it with a new unit. But that was not the problem. Anyway HELP!!! Thanks
PS Now I find that if I hold the PTO switch all the way up in the reverse position, the engine and the mower work find? Help!!!!
Ted
PS Now when I start the engine release the brake and pull up the PTO it stays in the up position and I can mow in forward and reverse. But If I hit a bump the switch goes into the middle position and the engine stops. When this happens I immediately push down on the PTO and the engine run and the mower stops. IT appears to be the middle position that is not working. Could The problem be the PTO?
Year: 2018 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 55446 Pla... (A53424)
Year: 2018 Make...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
American G-Model Pump Jack (A55218)
American G-Model...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
