Scott's 1642 transmission leak K51A
   / Scott's 1642 transmission leak K51A #1
Teepster
Bighamton ny
scott 1642
My k51a has a small leak coming from where the brake connection goes into the left side of the transmission. I had the transmission out for the drive pulley fix so had a chance to study the leak area closely and I'm sure that is the problem area. I ordered the repair seal kit and replaced that and reassembled everything and still have a slow leak coming from that spot. The seal is a little tricky to get in. It wants to fold up when you push it in. I can only think it did not get seated properly. Has anyone else encountered this?
A TIP FOR TOPPING OFF THE FLUID: Anyone who has had the K51A out would see a access port on top of the tranny. It is not normally assess-able while in the tractor. If you remove the battery under the seat and have an idea where this port is you can cut a hole about 3inches square in the frame right above the access port. With a small screw driver you can pry off the rubber/metal cover and add fluid. I cut out a small sheet metal square to place over the hole but probably not needed. I used my dremel tool to cut out most of the hole and then some with a sawsall. I would not recommend starting with a sawsall without realizing how close the transmission is underneath the frame. I'm currently living with my leak and check the fluid level about once a month and only have had to add a small amount to this point.
   / Scott's 1642 transmission leak K51A #2
It does sound like the seal install failed. Did you clean/polish the shaft before installation? Lube the shaft first? Sorry I can't be of more help.
Thanks. Did not clean/polish but was oiled. Worth trying another replacement seal after this mowing season. Bugs me having even a slow drip under the tractor. I can remove the brake assembly and drain the fluid thru that and then refill thru my homemade access point.
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
