Schwartz Cylinder Seal Kits?
   / Schwartz Cylinder Seal Kits? #1
scot4152
madison, pa
Yanmar LX 4500, Satoh-Mitsubishi Buck S470D
I have a Schwartz FEL that is on my Satoh/Mitsubishi Buck 470D. All 4 cylinders need new seals. The rod is 1"dia. and the Cylinder ID is 1.75". Anyone know where I can get them?
   / Schwartz Cylinder Seal Kits? #2
Find a good competent local hyd shop, bring in the cylinder completely taken apart......easy to match seals
wdchyd,
sound advice! I'll probably end up doing as you suggest but, it sure would be nice to find a company to buy them off of so I could repair them myself.
   / Schwartz Cylinder Seal Kits? #4
You can still DIY.....just buy the seals only from the hyd shop
   / Schwartz Cylinder Seal Kits? #5
What he said
You can look at company's like https://www.herculesus.com
But without know how to accurately measure and identify the seals you have it may be just a guessing game.
   / Schwartz Cylinder Seal Kits? #7
Rebuilding hyd cyl.
I would recommend taking it to a hyd shop and have them measure and fix the cyl and then test it.
Most people will not even know what to measure and how to measure.
You have to know things like bore diameter, piston diameter, land width, land depth, seal composition.
Need to check bore for scoring, any bulging, piston nut strippedand loose, rod bent, rod nicks, etc.
You might go to the hardware and find something close, and it might even work for a while, and then , and then, oops, to late, there she goes Fred.
Anyway, you can try it yourself if you want to. Some are easy and some are hard.
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
More info coming soon! (A50323)
More info coming...
Airco Tig Welder (A51691)
Airco Tig Welder...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
LMC LOT NUMBER 132 (A53084)
LMC LOT NUMBER 132...
JOHN DEERE 694' 6 ROW CORN HEAD 38" (A51247)
JOHN DEERE 694' 6...
