Curtisbbutler
Hi all. Does anybody have any input on Schaben Sprayers? I'm looking for a new 200 gallon PTO 3pt sprayer. Found shaben for around $2600-Pump included which seemed like a decent price for new sprayer. See details below.
Thanks in advance for the help.
Schaben 3-point Sprayers-200-gallon
Category-2 lift pins
Pressure head assembly
100-psi liquid pressure gauge
Hypro ョ 8-roller pump
USA made
Get a high-quality, 3-point steel-frame sprayer for any size job. These sprayers all have a heavy-duty steel frame to provide the durability for which Schaben is known. Built-in braces and nylon straps give you added tank stability during your spraying application. Feature a pressure regulator for bypass and agitation, as well as manually operated valves for boom or nozzle control. Each sprayer includes a 22"L TeeJetョ GunJetョ high-pressure aluminum spray gun with 200-psi operating pressure and 25-ft.-long rubber hose for extra reach. Gun holder and hose wrap included. Booms feature QuickJetョ nozzle bodies, Model 8003 spray tips and a T-valve for three-way boom control. 20" nozzle spacing. The PTO quick-coupler on the sprayer pump hose will fit either a 540 or 1,000 RPM tractor PTO shaft.
200-gallon 3-point Sprayers Fit a Category-2, 3-point hitch. Include a pressure regulator, 100-psi liquid pressure gauge and Hypro eight-roller pump with quick coupler. Feature an eight-row breakaway boom (28-ft. coverage) and a 200-gal. corrosion-resistant polyethylene tank. NOTE: Silver Series XLョ pumps are compatible with glyphosate herbicides. Specify standard Cast Iron or Silver Series pump from drop down box above.
USA made
