Scary wheel failure
   / Scary wheel failure #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
In the CTC parking lot in Smiths Falls today I saw a wheel hop off a horse trailer and follow the truck along over the speed bump before it stopped at the entrance to bay 2. The driver didn't believe me when I told him he'd lost a wheel, but he sent his wife back to check.
As he passed I had noticed the lug nuts were still in place; on the lost wheel five holes had worn through the expensive-looking alloy, but the decorative hub was still in place. I guess the short turn off the street combined with a heavy load and axle scrub to complete the destruction.
The female passenger took a look at the dead wheel and expressed great alarm, worried in retrospect about her load of horses.
I commented that she might consider a steel replacement.
The new, expensive truck-and-trailer rig shouldn't have dropped a wheel. Scary.
   / Scary wheel failure #2
I would say a good 1/2 of the 75 trailers I maintain have aluminum wheels. I torque everything to spec and never had a single failure.
Chris
   / Scary wheel failure #3
I was told years back even new or install double check w/in 500 miles on trailer..sometimes tech forget to double check even on new tractors w/fel etc. :(
I have to emphasize that the lug nuts did not come off. They pulled through the wheel, leaving holes. The nuts stayed and the rest of the wheel took a tour through the Canadian Tire parking lot.
A former student of mine is now a paraplegic after having an errant wheel come through his windshield. This is serious stuff.
   / Scary wheel failure #5
A ouick walk around your equipment to check for lights ,air pressure,license plates and other things should include looking for rust and dust on rims. Steel rims will eat through the studs if lugnuts nuts are loose. Rust and dust [powdered aluminum] usually means something needs attention. Trailer tires do not transmit as much "feel" back to the driver and should be inspected carefully.
   / Scary wheel failure #6
Seems like a good look at rims, and looking for hairline cracks would have worked. BUT occasionally, stuff happens. drive big rigs, lost only one set of tires, rims and all.(20yrs of driving) Some may pile on, and say there is no excuse, but.....
BTW, only go 100 miles and retorque lug nuts. A calibrated torque wrench is a must, along with clean surfaces. My nuts have to be in the 400lb range:laughing:
Let the games begin!
   / Scary wheel failure #7
Yep, I bet they were over torqued at some time.
I had a flat on the drivers rear of my brand new 1999 S-10 blazer when it was 4 months old. Actually had a kitchen fork in it. Anyway I could not get the lug nuts off. I had to walk a mile to a farm house, before cell phone days, and ask to use the phone. I called my dad and he told me what a dumb *^$%^$ I was but he was on his way to help with some tools. The farmer offered to give me a ride back to my truck and on the way he stopped to pick up a 7' long piece of pipe at his barn.
Well we got there and my dad showed up with a 3/4 drive socket set. We put the pipe over the wrench and actually lifted the tire off the gound without the lug nuts budging. My dad said just drive it to the dealer on the flat. It was a Sunday. I did and they had to replace every stud and all 4 wheels on it. They said they had to burn a few lug nuts off they were so tight.
Chris
   / Scary wheel failure #8
Interesting about the fork...I had a dinner fork stuck in the sidewall near the tread once...astounded me how it did that..tire was flat in 30 seconds, happened on trash pickup day just as I turned into my driveway. Apparently it came off the trash truck.
I used to joke- when you come to a fork in the road- what do you do?
You run over it:laughing:
Back about 86 I was coming home on Christmas Eve in a company Ford Van and had a flat. Could not get the lugnuts off even jumping on the wrench, and I'm not a little guy. Pondered the situation a few minutes, realizing I'd have a tough time getting road side help on Christmas Eve, so I drove the last 3 or 4 miles to the house on the flat. That tire was smoking when I turned in my drive:D
   / Scary wheel failure #9
Had a semi lose a wheel going the opposite direction on a divided highway.
The wheel followed the semi for a while, gently veer, cross the median, become airborne and bounce over the hood of my car barely missing my windshield.
My pants were close to being stained.
Everything happening so fast, you don't know if to brake, accelerate veer left or right or what.
You just pray, grit your teeth and hang on.
I figured that I earned the right to claim that wheel, heaved it into my trunk and promptly sold it at the next truck stop.
Heavy bas****d!
   / Scary wheel failure #10
The alloys I've seen come off are from loose lug nuts then the holes beat themselves larger from driving with it loose.
I don't like hubcaps!
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51246)
MAH QUICK ATTACH...
UNUSED JCT 84" HYD 4N1 BUCKET (A51248)
UNUSED JCT 84" HYD...
