I don't know your model, but my Scag Wildcat has been giving me issues with starting lately. At first I thought it was a dirty terminal on my battery because nothing happened when I turned the key, but my volt meter said I had 12.6 volts. I cleaned the terminal and it fired right up. Then a week later, nothing happened when I turned the key. Battery terminals looked great. I followed the path of power and everything seemed to be working. I checked every safety sensor with good results. Then I tried to start it again and it fired right up. Third time it happened I just focused on the safety buttons. Parking break didn't seem to be pushing it in all the way, so I pushed it in all the way with my finger and it fired right up. This last weekend it wouldn't start and nothing worked. 4 hours later, I spliced in a wire from the hot terminal on the water temperature gauge and another onto the blue wire with the white stripe off of the switch that goes straight to the starter solenoid. Both wires are hanging freely, and when I turn the key and touch the ends of the wires together, it fires right up.
I'm guessing the problem is the relay next to the key. I hate buying parts hoping they will fix it, but nothing is making any sense to me so far.
Eddie
