Scag / Kohler engine has me stumped
   / Scag / Kohler engine has me stumped #1
aloha
Hawaii - Big Island
Kubota B7800 / Kubota RTV X900 / Scag Turf Tiger
I have a Scag Turf Tiger ZTR with the 27 h.p. Kohler CH740 engine that has died and defies troubleshooting. The grass is growing and I am desperate for suggestions.
The Scag is 6 years old, 560 hours, and has been completely reliable up until now. 3 days ago I had just started mowing, and about 3-5 minutes after having started the engine the engine backfired very loudly and immediately died. (I had just started a right turn after having mowed a straight line for about 2 minutes when it happened, probably just a coincidence, but it did happen at the instant I started the turn.) When I looked at the engine the air hose from the air cleaner was off the carburetor, presumably blown off by the force of the backfire. When I crank the engine it fires and sounds as if it is going to run, but when I release the key from the start position the engine it dies.
I have confirmed fuel is being pumped and the carburetor fuel shutoff solenoid is operating correctly. I pulled sparkplugs and one was damp with a gas odor. Visual inspection of the carburetor shows nothing amiss, linkages are working correctly, although the throttle valve moves little from the full open position, which is where I normally run it. It appears that the fuel supply is not the cause.
I have checked that there are no obstructions to the air flow and attempted starting with the air cleaner removed. I find no problem with the air flow.
I have replaced both spark plugs. I have used a spark plug tester that shows both cylinders are sparking.
The local Scag guy said he has seen similar symptoms with a broken valve push rod. I pulled the valve covers and all push rods appear sound and straight. Pushing on the rocker arms showed all valves moving freely.
I have gone through the troubleshooting steps in the engine service manual, http://www.kohler-engine-parts.opeengines.com/pub/SM_2469006_CH18_thru_CH750_REV1010EN.pdf, and find no clues in those things I can do without special tools and which seem even remotely possible. I'd like to get a timing light on it, but it appears that would require pulling the engine from the Scag to get access to the timing marks, and with the engine not running except by the starter turning it there might be little to be learned.
The local Scag guy has 2 to 3 weeks of repairs backed up, so I am pretty much on my own. And having determined gas apparently ok, air apparently ok, spark apparently ok, and the main mechanical components apparently ok (at least those that can be seen without seriously tearing into the engine) I have run out of ideas.
So, someone please show me that I am an idiot and have overlooked something easy. Or even something not so easy. All ideas are welcomed. Thanks.
   / Scag / Kohler engine has me stumped #2
Unhook the wires at the keystart and jumper the solenoid, sounds like a hot wire is grounding...if no luck try disconnecting everything but the battery main and jumping it again.
   / Scag / Kohler engine has me stumped #3
A backfire that blows the air hose off the air cleaner was a backfire. Have you checked the compression on both cylinders? The backfire could have dislodged a valve seat. The backfire could also have sheared the flywheel keyway or caused it to slip. Have you checked the seat safety interlock switch? Are the other safety switches, deck and gearshift etc., still all plugged up?
Most Koehler’s use a white wire to ground the ignition coils, can you temporarily disconnect the ignition coils ground wire to see if it will start?
Will your Dealer provide a copy of the electrical schematics for the machine?
   / Scag / Kohler engine has me stumped #4
My Craftsman ZTR with the 26 HP BS engine died recently while mowing (still under warranty) and it was the parking brake safety switch. It was running well and just quit but mine would start up then die when I tried to move it. Yours could also be a safety switch problem although when mine are acting up, the engine wont turn over unless all controls are set properly.
   / Scag / Kohler engine has me stumped #5
Are you sure your getting spark? I'd hold the spark plug near the head or something and make sure you see spark. If you are sure your getting spark, try spraying a little starting fluid in the carb and see if it wants to run better. If it starts and runs a little bit with starting fluid, you might be getting gas, but not enough.
If its not any better with the starting fluid, and you are getting gas and spark, that means you are getting spark at the wrong time, and this is my best guess what is wrong with your engine. You said something about timing. How are these things timed? Is there a way to adjust it? New ingnition module? Of course it could also be mechanical, broken piston, bad valve etc, but this would require a tear down to find.
I'm just throwing out ideas and guessing a little, good luck.
Thanks to all for the thoughts and suggestions. I may be on track to sorting this out.
Compression looks good -- about 143 psi in both cylinders. The Scag service manual does not say what it should be, but no obvious problem here.
I have tried starter fluid. If anything, the engine fires less when I spray a good shot of ether in the carb, which I would say is impossible if someone else said this was happening and I had not seen it myself.
When I look down the carburetor throat while cranking the engine and the choke open I can see fuel pulsing in.
It does not appear to be a problem with any of the safety switches since the engine cranks and spark plugs fire, the engine just does not maintain speed when the key returns to the on position. I have confirmed the spark both using an inline spark plug tester that lights up when there is a spark, and pulling the plugs, grounding them, and seeing what appear to be good sparks across the gap.
I am unable to check spark timing since the engine won't run.
What I have come to suspect is that it is electrical, as suggested by Fixemall and Gator6x4. The clue being that when I crank the engine it fires and sounds as if it is going to run, but when I release the key from the start position and it returns to the one position the engine it dies. This seems to suggest that there is a problem in the switch or the kill circuit, and the engine is being killed with the switch in the on position. Sorting through the wiring, and trying to make sense out of what the service manual says, is proving very time-consuming. I will have to get back to it tomorrow.
In the meantime, any further ideas and suggestions would be most welcome. Again, thanks to those who have responded.
   / Scag / Kohler engine has me stumped #7
i think it was just due to a little mistake
   / Scag / Kohler engine has me stumped #8
From what you describe, it almost sounds like you are not getting spark when you let go of the key. In other words, the run position is not run but off. Is there a way to check to see if you get spark on the run position? Can you bypass the keyed switch in some manner and get the thing to run? If it were me, I'd try to bypass the key switch in some manner and see what you get.
Did I say I hate electrical problems? Good luck!
I, too, hate electrical problems.
One local mechanic opined that it sounds like a problem with a safety switch. I must disagree since the engine cranks and spark plugs fire, the engine just does not maintain speed when the key returns to the on position, and I have checked all safety switches and all appear to be operating correctly. Fuses are good. All wiring connections seem to be attached.
I have confirmed the spark both using an inline spark plug tester that lights up when there is a spark, and by pulling the plugs, grounding them, and seeing what appear to be good sparks across the gap. However, the spark stops immediately when the ignition switch goes from the start position to the run position.
When I disconnect the kill leads from the ignition modules I get no spark at all.
I need to think it is an electrical problem since the difference between the spark plugs sparking and not sparking is whether the starter switch is in the start or run position. I am struggling to make sense of the ignition switch so I might try using jumpers between wires to try isolating the problem. The Kohler and Scag wiring diagrams are not as helpful as they could be, in part because the Scag diagram shows wires going to "engine" without indicating what engine components the various wires connect to. There is a part called "electronic module" which appears to do magic with various circuits including the safety switches, but appears to be untestable.
I am getting a bad feeling that unless I get this figured out myself, what passes for an expert mechanic around here may spend many, many hours on the troubleshooting as I have and may hand me a bill calculated to fund his retirement.
   / Scag / Kohler engine has me stumped #10
Generic keyswitches are like $10, I keep several on hand...might start by replacing it to rule that out before diving into the wires. autozone carries them.
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
LINDE H70 FORKLIFT (A53843)
LINDE H70 FORKLIFT...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
