SC2400 PTO selector lever
   / SC2400 PTO selector lever #1
sauer
WA
Yanmar SC2400
Just finished installing the MM60RSE.
I have ever used the MM PTO before.
I tried to move the selector lever and it feels like it half way engages to the "both" setting, and won't budge any further towards the "Mid" setting.
I tried it both engine running and off. I did not try to switch it with PTO engaged
I checked the linkage and do not see any obvious binding.
Any ideas? Still in warranty but I'd like to avoid hauling it if I can.
Just went out and checked it again. It is NOT fully engaging the mid PTO when I push it towards "both". Mower deck spindle/belt is not moving at all.
If I apply pressure on the lever (pushing towards "both" and "mid" when PTO running it makes a terrible groaning/moaning sound.
Also, the lever/linkage are not binding at all.
Rear PTO functions just fine (all I've used past 4 years).
Thinking this is internal to the PTO housing.
I don't think in the 4 years I've owned this that I've ever even moved that PTO selector lever.
Please let me know if you'e experienced anything like this. I will be going to the dealer tomorrow.
   / SC2400 PTO selector lever #3
I know when I put on my front mounted snowblower, I have to sometimes rotate the snowblower pto shaft a little to engage the mid-pto lever.
God bless you sir, I owe you a rootbeer!
Rotated the MM PTO shaft just a little bit and the PTO selector lever moved forward and fully engages all positions now.
THANKS AGAIN
   / SC2400 PTO selector lever #6
Just wanted to let you know this helped me out this morning. For the first time since I've owned the 2450 since it was new I had an issue switching to the MM PTO. Your solution solved the problem, thanks!
2015 DODGE RAM...
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
UNUSED FUTURE MINI...
2023 JOHN DEERE 333G SKID STEER (A51242)
2023 JOHN DEERE...
(9) SHANK ALL PURPOSE PLOW (A51243)
(9) SHANK ALL...
