satoh sticky clutch
   / satoh sticky clutch #1
ericdelo
my tractor ,a satoh beaver 3cyl 15 hp,was park for 3 months .I started it by pulling it with my pick up.
and now the clutch is sticky even i press the clutch pedal it continue to run.
anyone as a solution for this problem
   / satoh sticky clutch #2
I've had a similar problem on one of my machines. I put the box blade rippers down, then dropped the blade into the dirt, and pressed in on the clutch most of the way.
That let the clutch slip a little bit, and free the corroded material that was bonding the clutch plate onto the disk. I also lubricated the clutch release bearing, and adjusted the free play in the pedal first. A couple cycles of slipping the clutch freed everything up, and now it works fine. Good luck!
2015 DODGE RAM...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2013 RAM 4500 (A50323)
1264 (A50490)
1264 (A50490)
2014 INTERNATIONAL 4300 18' REEFER BOX TRUCK (A54607)
2014 INTERNATIONAL...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
