satoh ST1620 need radiator hoses
   / satoh ST1620 need radiator hoses #1
texas
satoh st1620 4cyl diesel
do ya'll know where i can get the upper and lower radiator hoses for this tractor, it is also the same as the mitsubishi D1650 has the K4A diesel engine. also, how could i put a mechanical temp gauge on it or one that would run off the original sending unit. thanks :)
   / satoh ST1620 need radiator hoses #2
You could go to any parts store and get the temp gauge but it will come with it's own sender. I don't know if you can get an electric temp gauge, most are mechanical and the sender, capillary tube and gauge are one piece. You will have more tube than you need and will just have to keep some rolled up and tucked away. Take your electric sender with you to match threads in case you need an adapter. For other stuff:
Valley Power
Japanese Tractor Repair Dixon, IL
201861 (A54756)
201861 (A54756)
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
RoGator RG1100C (A55302)
RoGator RG1100C...
Loader Bucket (A53421)
KUBOTA M7-132 (A53084)
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
