Satoh S650G - Soaring RPM problem
   / Satoh S650G - Soaring RPM problem #1
JTbowman
Hi All,
I have owned an Satoh S650G for a couple years now, and recently a new problem has showed up. It runs OK but at time, especially when the load get lighter (i.e. going down a small hill) the RPMs start to soar, and get up to 3000+. Throtteling all the way down doesn't always help and to get it to stop I sometimes have to kill the engine. I recently worked on the carb and replaced a worn out accelerator plunger. Other than that I think it all looked OK.
So I suspect it my be some kind of carb adjustment I need to make or possibly something with the governor. Please let me know if you can help.
   / Satoh S650G - Soaring RPM problem #2
if you trottle down the rpm should go down on a good working tractor.if this does not happen something is preventing the butterfly valve from closing.this could be something in the linkage or the governor or both.sounds like something is flipped flopped cause it should trottle down on lighter loads.
   / Satoh S650G - Soaring RPM problem #3
I have the same soaring RPM problem with my S650. Does anyone have any decent adjustment instructions for the throttle and governor? The manual is very vague.
Hoverdave
   / Satoh S650G - Soaring RPM problem #4
i just change the fluid in the governor when the rpm's go crazy.If its milky that would be your problem
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
Miller Millermatic 130 XP Welding Machine (A50860)
Miller Millermatic...
2011 MACK GU713 (INOPERABLE) (A50854)
2011 MACK GU713...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
