Satoh S650G Brakes
   / Satoh S650G Brakes #1
oldtractorlover9
I recently purchased a Satoh S650G.
The brakes work fair. By this, I mean the pedal must be be depressed all the way before they stop the tractor.
Can somebody help me?
Is there an adjustment?
What type of brakes does this tractor have?
What is the difference between wet and dry brakes?
It is a pretty neat little tractor for brush hogging, but due to the terrain, I need good brakes.
Any help will be much appreciated!
   / Satoh S650G Brakes #2
Welcome to TBN!
On my Mitsu, there are adjustements on the links (shafts) going from the pedals back to the brake actuator arms.
Tighten them up a bit and that should help.
Welcome to TBN!
Thanks for the help. I adjusted them up, and now have fine brakes.
Ez-Go Golf Cart (A50121)
Ez-Go Golf Cart...
Toro Workman Utility Cart (A51694)
Toro Workman...
International Tractor w/Belly Mower (A50774)
International...
ATTENTION! PLEASE READ (A50121)
ATTENTION! PLEASE...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
