Satoh S370 Clutch Problem
   / Satoh S370 Clutch Problem #1
b'stractor
Oklahoma
Satoh S370
Hope someone can help me with my problem.
Earlier in the year my clutch stuck and I was able to get it to break loose by pushing in the clutch and hitting the brakes. Seemed the clutch was stuck to the flywheel. A few months later it happened again and I was never able to break it loose.
Since then, I have split the tractor and replaced the clutch and pressure plate and I still have the same problem. I have had the tractor apart numerous times. The new clutch has never been stuck to the flywheel. I have adjusted the linkage in every postion possible and the clutch still will not disengage.
Does anyone have any advice as I am at a loss? :confused:
   / Satoh S370 Clutch Problem #2
I had the same problem to occur twice on my Satoh Beaver. First time, I split the tractor and easily peeled the cluth from the flywheel. Second time I broke the transmission jabbing the brake with the clutch depressed. When I pulled the tractor apart, the clutch again peeled easily fromt he transmission. Second time I made sure I sealed between the transmission and the bell housing. Never had the problem again. Over winter, I would put a board between the steering wheel and clutch pedal.
I have had car brake shoes to stick to drums when the parking brake was left on for months. My personal old car, I had to slam it from forward to reverse to brake the shoes loose fromt the drums.
Just be careful jabbing brakes. If mine sticks again, I will make an opening in the bellhousing with a saw or other means to make a hole to poke a screwdriver through to pry the clutch disk back. On the other hand that may not happen because mine is broken due to loaning out.
   / Satoh S370 Clutch Problem #3
A lot of these tractors have a latch that you can hook to clutch linkage when the pedal is depressed, holding the pedal down. This is to prevent your sticking problem.
Thank you for your replies.
Every time I have taken the tractor back apart and loosen the bolts on the pressure plate the clutch plate slides freely leads me to think the clutch is not sticking, but I may have a linkage problem.
I have noticed there is wear on the clutch fork where the fork makes contact with the throwout bearing yoke. I am curious how much wear is acceptable or if there may be an issue with the shaft the clutch fork is attached to?
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
