Satoh PR-1100 Tiller ; where is safety clutch Mechanism?
   / Satoh PR-1100 Tiller ; where is safety clutch Mechanism? #1
rossasaurus
Sebastopol, CA
Satoh Beaver w/PR-1100 Tiller
Have a Satoh Beaver with PR-1100 Tiller where tiller is chattering under load. Vibrating violently and not turning.
Is there an accessible pto drive clutch for this tiller and where is it?
pto still turning, horizontal shaft still turning.
Is clutch under chain drive cover?
thanks
   / Satoh PR-1100 Tiller ; where is safety clutch Mechanism? #2
Clutches or sheer pins are usually on the PTO shaft or where the PTO connects to the gearbox. You can see where the motion stops. Your assessment of "violent" is probably correct & is the result of parts busy turning themselves into metal shavings.
Crack it open & see what you broke.
Thanks Fallon,
Yeah I'm used to seeing clutches up top on tillers, but this has none out in the open,
and only drive accessible at all is a chain housing on the one side, so will have to try there.
Not expecting a wet clutch though.
QUOTE=Fallon;4900664]Clutches or sheer pins are usually on the PTO shaft or where the PTO connects to the gearbox. You can see where the motion stops. Your assessment of "violent" is probably correct & is the result of parts busy turning themselves into metal shavings.
Crack it open & see what you broke.[/QUOTE]
   / Satoh PR-1100 Tiller ; where is safety clutch Mechanism? #4
If there is no clutch, or at the bare minimum a sheer pin on the PTO shaft, that would explain the next weakest link breaking. I'm 99.9% sure you arent going to find a clutch or sheer pin in the chain case on the side.
ok, thanks for responding Fallon
2021 Chevrolet Silverado 4500HD / Silverado 5500HD Flat Bed, VIN # 1HTKJPVK3MH814615 (A51572)
2021 Chevrolet...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
