Satoh manual steering gearbox oil
   / Satoh manual steering gearbox oil #1
Burnie46
Northern Pa
Satoh S650G
My 650G very hard to steer when temp. is below freezing.No drain plug or checking plug, could there be water in it?
   / Satoh manual steering gearbox oil #2
Hi.....Years ago I had a 650G. It had power steering but that was really controlled buy a hyd. cyl. mounted in place of the steering link. So I think the steering box was the same, mounted down at the end of the steering column.
Anywho, I could not turn the steering wheel after sitting outside in the winter. I heated up the gear box with a bernzamatic to get it inside. I then drilled a hole, threaded and put a pipe plug in it. Added new oil and worked fine.
Yes yours is probably froze, at least my was. George
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
Wolverine 72" Hydraulic Skid Steer Tiller, New  (A52384)
Wolverine 72"...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
DoD 88-20041 12.5kVA Brushless Diesel Generator (A51691)
DoD 88-20041...
2011 Hyundai Sonata Sedan (A51694)
2011 Hyundai...
