Satoh Elk S550G how hydrologic fluid does it take
   / Satoh Elk S550G how hydrologic fluid does it take #1
Middle ga man
Gordan Ga.
1974 Satoh Elk S550G
Can anyone tell me how much hydraulic fluid goes in a Satoh Elk S550G. Or is there a plug or somthing to level it by. Also does the tranmission use a seperate tank for fluid it has a fill plug on the top by shifter. If someone will please let me know asap .
   / Satoh Elk S550G how hydrologic fluid does it take #2
Just saw your post. General answer is in the old days Ford had 3 sumps, tranny, hyd, diff. Then in the mid 60s they went to 2 sumps, tranny and hyd-diff combined and used hyd fluid with special additives for the combo. Then comes modern tractors with common sump for all 3 functions plus hydro. steering, plus wet brakes that never need brakes nor pads and if 4wd a forward sump at each wheel interconnected through the common drive diff and shaft.
Usually the fill plug for a sump is over the sump somewhere, at the top of the general casting. Full for any gearcase is never full. It's usually half way. For older equipment, FULL plugs would be pipe plugs of ⅛ to ¼ inch or a dipstick. The full plugs would be located about half way down the side of the casting involved with threads directly into the casting to accept the plug. Pour fluid in the fill hole till it runs out of the full hole.
For what fluid to use, a Ford 134A or JD 303 which is a trans-hydraulic fluid for older equipment without hydrostatic steering and wet brakes and all that newer tractors have to go along with their common sump used for tranny/hyd/and diff. For the newer tractors with such, I just look for the JD 20C spec which usually appears if anything does and if it's there usually the Kabota UTD is too and those 2 specs seem to cover everybody's equipment. Another thing is that the latter is usually referred to as "Premium Trans Hyd Fluid" and a lot of times it's dyed a faint orange to identify it from the 303 type oil.
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2017 Ram 5500 Crew Cab Reading Service Truck (A52377)
2017 Ram 5500 Crew...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
