Satoh Buck won't start???
/ Satoh Buck won't start??? #1
Rowdy Raven
Bronze Member
Kubota L3010
Hey Folks,
I have a Satoh Buck 3cyl. Diesel that I mowed with recently. It cranked fine as it always has and ran fine. After mowing for an hour or so I stopped and disconnected the mower and then went to move the tractor. However when I turned the key nothing happened. I had it in nuetral, clutch depressed... and nuthing... nada. I waited a few minutes and tried again, this time (with the hood up) I heard a click and saw a faint puff of white smoke come off of the positive terminal. That was it, nothing else... tried again a few minutes later and nothing at all. I have checked the battery it load tested good. I have checked the battery terminals and they are clean and tight. I checked the grounding to the tractor and it is good. This tractor has never given any issue like this ... any ideas would be greatly appreciated, thanks!!!
Rowdy
DBL SQUIRREL CAGE FAN ON ROLLING STAND (A63290)
DBL SQUIRREL CAGE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2003 Ford F-350 Flatbed Chemical Sprayer Truck (A61573)
2003 Ford F-350...
iDrive TDS-2010H...
